what if im stock and i put 550's can i do that?
white 90 gsx
216
Sep 4, 2002
ft lauderdale, Florida
I need to replace my injectors so im deciding to put my new ones in is that ok to put 550's on a stock 1990 gsx will it hurt anything?
You need fuel control. If not you will run Obscenely rich. But if you do that and a Fuel pump, you will be able to squeez every last bit out of your 14B and not get fuel cut.
there were 510CC injectos that would work right with your car, they came with the 16G equipped motors.
thought you had an afc2.... or do you have it mounted, but not hooked up like your front mount intercooler a few months ago ?
