koreanpersuasio
- 203
- Jul 15, 2002
HI. I went to DSM.org..and it was a lot of help, but it didnt answer these naggin questions. I dont want to hurt my car. Will i run the possibilty my engine going lean? I was just going to do the following:
1add the test pipe
2add manual boost controller (only add 2-3 psi boost?)
3remove the restrictor in the wastegate
4possibly upgrade the uic piping
I have the stock exhaust, stock turbo, stock fuel pump and injectors, turbo xs bov, msd ignition wires.
If i do the above mentioned items, will i be in danger of running lean? I have a boost gauge.
1add the test pipe
. I am putting in a boost gauge, boost controller, intake pipe, upper IC pipe next week. Might this help?
. I have stock turbo.
What can go wrong with a mbc?
