Leo97GST
Banned Member
- 28
- Apr 17, 2003
Hey Guys, I'm new to the board. I've been looking around and it looks like we got some knowledgable DSM'ers up in here, which is good cuz I need the help!
My stock 97 GST crankwalked this past week and I got a 1g longblock for a replacement motor. The block a 94 turbo and is complete except for the turbo and accessories. Here is my question, what do I need to take off my 2g block in order to get this bad boy back up and running.
Here is what I know so far...
Use the 2g Starter Plate
Use the 1g 6 bolt flywheel
Use the 2g Accessories/brackets etc.
Modify the 2g motor mount to fit on the 1g (since the waterpump is in the way)
Can I use the turbo off the 2g? If so will I have to use the 2g manifold? Is there any benefit to using the 2g manifold, is it bigger?
What electronics will I need to swap off the 2g (i.e. TPS, MAP, EGR)?
Will I need to customize a harness for the CAS sensor? If I don't have one ready will the engine still run?
I'm looking to get the most power and most reliablilty out of this setup so any additional help would be greatly appreciated. Let me know what you guys think, thanks!!!
