larryd
- 4,546
- 5
- Nov 26, 2001
Bear,
Delaware
since the BR site really doesnt tell you jack I was hoping maybe someone can tell me a few things..
Ive figured they require an external wastegate, is a tial 40mm doable with the Victory Performance O2 Mounted external wastegate a good setup for this turbo?
Im assuming the turbo is NOT a direct bolton, is there a kit required and if so where can I get it and how much since I cant find this info anywhere..
Is the intake inlet on the turbo 2 1/2" or 3".. just trying to figure out if Id have to get rid of my Injen intake for a Dejon Tool or not..
Fuel Wise.. is my 190/550 setup good enuf or would I need a 255hp to replace the 190?
any to answer the question Im sure Ill be asked, yes my turbo the FPBig28 is shot.. its not a piston ring as I thought, its actually the turbo causing the problems and Im up in the air on the Green or the BR20G..
ill post the description
. And my car is mainly a daily driver not a strip car.
