forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Recently blew a HG so I swapped heads. The head I swapped in had the original lifters in it. I didn't like the noisy drive train so I decided to swap in my revised lifters from my old head. (always had quiet valve train with it)
After doing this today I fired the car up and it ticks like mad. I know the lifters have to pump back up, but I let the car idle for a good 10 mins and come up to temp. Still clacking like mad. Even worse than before. I did bleed down the lifters before install.
Any tips? The 3G lifters I installed were defiantly in good shape and were all still "pumped up". I used a paper clip and bled them all down, then I blew all the old oil out lubed them up well and installed them.
I've even tried reving the engine up a few times to help get the oil pressure up. No luck.
