draculia
- 203
- Feb 11, 2003
Cape Cod,
Massachusetts
comp clearance
Originally posted by draculia
comp clearance
Originally posted by Scotty
Milling the turbonetics ex manifold to clear the coolant tube would push the exWG even further into the hood. I'd rather dent the tube slightly than a even larger dent in the hood.
Originally posted by JayHass
You would be moving the TURBO, not the manifold
Wouldn't that just cause another fittment issue for the bolt-on crowd? By clocking the turbine housing you also clock the o2 housing. Then you would have to also modify the downpipe or the o2 housing so the flanges mate correctly.
