dave c
- Mar 11, 2003
Has anyone took the balance shaft and turned it down on a lathe , removed the other bal shaft, and had good luck with the results?
Another mod some people have been doing (being more paranoid than even me) for very high revving engines is a modified rear balance shaft. They basically chuck the rear shaft in a lathe and cut the balance weight off of the shaft. The advantage to doing this is that the oilpump shaft is fully supported in the oilpump case and farther back in the block. Personally, I don't think this is necessary for the average DSMer, but if you plan on winding your engine above 8000rpm, it might be something to consider.
Not if you balance shaft is still in there.samnumba1 said:i bought a stubby shaft and accidentally stripped a screw on the oil pump...(the one that the rear balence shaft connects too) just wondering on a 2g is there a way to get the shaft in with out takeing off the oil pump?
For the rear balance shaft it only shows you how to remove the shaft from the oil pump, which is very different on a 2g than the 1g shown in the vfaq (theres no need to remove oil pump from cover to remove balance shaft and install the stub, you just have to unscrew the cap on the oil pump side and loosen the bolt holding the shaft, then replace with stub and bolt back on the put cap back on also).
samnumba1 said:i have subby.. i just need to know if you HAVE to take apart the oil pump on a 2g to get to stock rear balence shaft?
Do not do thissjgYFZ200 said:Just snip the belt off the front balancing shaft and call it a day. I guarntee you people on here will disagree, but its completely fine. I left them both in, just cut the front belt off so there is no chance of it snapping and taking out the T belt.
CyberEye said:you'll find more people agreeing with cutting the belt then disagreeing.
Yep, use vasoline, that way it will heat up and melt, some "grease" like the vfaq says has a very high temp rating and will not melt. I have done this with vasoline and it works very goodsamnumba1 said:it says in the VFAQ to "Pack the gears and space in the rear cover with grease " so do I just put some vasoline inbetween the gears and between pump and front oil cover??to prime it right?
boostedinaz said:Here is a thread about the cut down shaft and how one was made.
http://www.dsmtuners.com/forums/showthread.php?t=183505
