Fuel Pressure Regulator Question
DELTA_Rotary
147
Oct 17, 2002
Ok Im finishing up on my fuel system on my talon. The previous owner of this car has a crappy B&M regulator on there now. My question is can I simply remove the B&M and bolt on a Aeromotive Regulator or are there some other things you have to do to the rail first? I really need to be able to lower the pressure because I have the huge task of trying to get 720cc Densos to idle with just an AFC OMG
no you cannot just bolt an aeromotive on.
It takse AN fittings welded to the rail. It's a completley different process.
Hmm do those fittings usually come with it?
You can either put your own together buying the fittings and everything from summit or you can spend more money and get the one thats already pre-assembled and ready to bolt on from Buschur Racing.
BR/SX Fuel Pressure Regulator Kit 275.00
