Wastegate setup
FastRthenU
582
Dec 15, 2002
I just have a quick question. I was thinkin of buying a Frank 2, and wanted to know. If i mount the extrenal wastegate on the o2 housing. Is a 35mm tial going to be to small?:confused:
OK..no.. what the hell you mean you mount the external wastegate on your o2 housing.... Its either external.. or you get those dope expensive o2 housings so you can have a external wastegate.. butit dumps back into your exhaust... instead of the atmosphere.. so its not nearly as loud..But candela is right NO..
No. 35mm should be just fine unless you plan on running low boost...
