DSMRevolution
- 1,629
- 11
- Dec 6, 2002
Sioux Falls,
South Dakota
I know that there were people on here that made a wastegate dump using their stock o2 housing. What I was wondering is what is involved to do this using the stock o2 housing. From what I assume, you would just cut off the wastegate tube where it goes to the o2 housing and weld a piece of metal to seal the hole up. From there you would just weld a open wastegate dump tube to the flange where you cut off the old one.
1. What size pipe would I want to use?
2. How long should it extend?
3. What kind of pipe should I use?
4. From where would I get it?
5. Will it flow as well as a aftermarket o2 housing that would already have a dump tube?
I am sure that I missed something but if you have any information for me please help!!!! Thanks
EDIT: Also Buschur Racing has this:
DUMP TUBE KIT
(TUBING AND FLANGE - U WELD)
Stock #: 30600-BR Price: $50.00
But I am assuming that this is to use a ext. wastegate. Any ideas?
DUMP TUBE KIT
. I did read a book about welding that they handed out start to finish without being told though!
Thanks for the answer though about welding it. Its been done many times on this board and on talk so I assume its possible.
. Does anybody have any idea what i can do now? Am I just gona have to be strict with the welding shop and tell them to weld it or can i use the mig welder at school? I have no idea on what to do for this project anymore. Should I even attempt to weld anything my self?
I didn't know you couldn't MIG weld them together
thanks
