nolv4v8
- 104
- Oct 21, 2002
Milwaukee,
Wisconsin
I finally narrowed down my turbo choices to these final two: the AGP L2 and the SBR G50. Both are nearly identical, but have a few small differences that I would like you to comment on. Here are the specs:
Garrett T04E 50 trim
360 thrust bearing
Garret T3 Turbine wheel
7cm2 Mitsu housing
3" inlet
The differences I saw were in the turbine wheel and the internal wastegates. The AGP L2 has a stage 3 T3 turbine whereas the SBR G50 only has the regular T3 turbine which I am assuming is stage 1. Also, the L2 only has a 34mm wastegate whereas the G50 has a 38mm. If you have any input please let me know. I know both companies are extremely well known and reliable and I have already done the searches and read almost everything about both. I would just like some personalized advice. Also if anyone has these please post your reviews on it if they haven't already been posted. Thanks in advance and I will definitely post which one I choose and the outcome of that decision.
BTW, following turbo question rules here will be the setup:
All the stage 1 mods (FIPK, BOV, piping, full exhaust excpet O2 housing)
ACT 2600 Street clutch
Walbro 255, ChargedAir 2G AFPR, 650 ball/disc injectors, S-AFC
RRE Griffin, VPE, IRC FMIC Kit (not yet purchased, another decision
Logger, EGT, Jumptronix A/F
That is pretty much it, but eventually a complete engine build up will occur, but hey you aren't going fast unless you are blowing it up or breaking it. Lastly, even though this post is long enough, does anyone else know of any times these turbos have turned yet? Thanks again and sorry about the length.
360 thrust bearing
7cm2 Mitsu housing
3" inlet
)Logger, EGT, Jumptronix A/F
