1G-3G Eclipses
Banned Member
- 85
- 1
- May 6, 2007
Indianapolis,
Indiana
I did a search on tuners. Also on google. Didnt come up with MUCH.
I did find, however, that;
Domestics are 3mm bigger on the fuel rail side
Imports are 2mm bigger on the motor side.
I would imagine the fuel rail side problem would be easy to take care of, either bore the rail 3mm larger. Or cut away at the injector (boring the rail seems a lot more logical here
But the motor side is what sort of concerns me. Is it possible to just get a fatter O Ring? would it still seal around the injector?
The only reason Im worried about this is because I can get a VERY good deal in a trade on these (saving about $150). I know someone has done it before just cant find the info.
Thanks in advance guys!
)But the motor side is what sort of concerns me. Is it possible to just get a fatter O Ring? would it still seal around the injector?
