Best BOV for venting /w VPC?
Antilles
305
Aug 25, 2002
Savage, Minnesota
What BOV would be best for venting with a VPC? I know they suck in air at idle and i am wondering if they open wide enough to cause problems...i.e. should i get one that has an attachable filter and what ones come with such filters?
Would the stock 1G work crushed? This is going to be for a 25psi+ application. And could you get filters for something like that?
and i dont care what it sounds like :rolleyes:
It works opposite to normal BOV's. It's a pull type so you don't need to worry about that.
The hks bov is a pull type relief valve, unlike other bov's dump valves which are push type i.e. diaphragm and piston types. The hks one is actuated by pressure alterations only, making valve response a little bit quicker and complete closure during idle. Regular types of bov's must utilize large valves or use washers or screws (to alter spring pressure) in order to accomodate high boost applications.
Austin
Oh yeah, the ssqv also has 2 valve. Its got a small one for really quick operation and a larger one for additionol pressure release. My friends 240 has one on it and he can just repeatedly tap the throttle and you can just hear the bov react so fast... pssh pssh pssh as quick as he can tap the peddle. pretty cool if you ask me
It bolts up to an HKS flange you have to buy seperatley.
I'm going to have to chime in for the Tial compressor bypass valve...
Originally posted by Antilles
What kind of flange does the HKS bolt up to? It seems that dejon does not make a UICP flanged for a HKS BOV.
yes they do and i have it! i think i payed 165. go check the site again u are interested in an hks bov. u just install it with a c clamp.
  • For sale 2g hatch panels
    Have right and left rear hatch panel and overhead hatch panel
    • mpedraza
  • Wanted 2g Ac tensioner
    Looking for ac tensioner and pulley for 2g
    • Simo_217
    • 92AWDHX40
    • eclipsemf
