- 10,748
- 59
- Jun 13, 2002
Chapel Hill,
North Carolina
Alright,here is what is going on:
I put in a new 16g about two weeks ago, only to find that after the swap I was leaking oil pretty badly around the flex section of the oil return line. Replaced that and I stopped burning oil. Here is the problem: I am throwing a CEL that I have not had the time to pull a code off of (planning on this tommorrow). When the CEL is on, I seem to be running on 2 cylenders; hell, I am getting smoked by hondas The RPMs go up when I step on it, as does the boost, but it basically bogs somthing awful. I had the good fortune of having the CEL go off for like an hour night before last, and finally got to feel 17psi on the 16g. One thing I should mention is that in the process of taking stuff apart for the turbo swap, we cut the lines going from the A/F guage that were tapped into the wires coming out of the O2 sensor; also the wires that hook into the sensor look a little charred. Could this cause this big of a problem or do y'all think the problem lies somewhere else? I am gonna replace the O2 sensor tommorrow anyway, but I just wanted some feedback on possible causes to this b/c I'm about to drive this thing into a ditch Any help would be greatly appreciated, and sorry for the long post.
Trace them back, and inspect it the whole way. If you have a test light, see if you can find a short and/or a lack of power to a specific wire or series of wires. I'm not very good at electronics/wiring but this is where I would start.
