Best fuel setup w/ a Big t28
190 lph pump, 550 injectors and a S-AFC. Without the fuel improvements keep the boost around 14psi or you'll hit fuel cut. With the above you should be able to run 20psi with good tuning. ;)
Good luck
Are you guys sure about the 3kgt fuel pumps? I have a 94 VR4 (trying to sell it for a 2G DSM) and our fuel systems are pretty weak. If you are going to upgrade the pump I wouldn't even bother with the 3kgt pump. We have trouble running 14 pounds of boost on the stock fuel system. Granted, some of it is the injectors, but the pump is also a factor. Most 3kgt guys end up with the Walbro 255.
stocker for you guys is like 180-190 or so. rewired is about 240. plenty of fuel for us dsmers
Originally posted by larryd
rewiring the fuel pump does not up the flow rate of the fuel pump
I believe it does if the voltage that the pump gets after a rewire is higher. The RRE table on the link I posted shows different flow rates for different voltages.
Well, I'm certainly no expert, but that does seem to be what the RRE table shows. I would think, though, that if you're getting sufficient voltage as is, then a rewire wouldn't affect flow very much. I'm in the process now of trying to figure out how to hook a multimeter up to my pump to check my voltage before I go through the hassle of a rewire.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
