Eliminate the 2nd O2 sensor
ted_the_mexican
80
Apr 24, 2002
Eldorado, Ohio
i want to put a test pipe on my car but there is the pesky little 02 sensor behind the cat.
without removal will the engine run right?
is the check engine light the only problem with the test pipe?
is there any way to remove it so the engine light stays off?
Unscrew it, ziptie it up, find something to screw in the hole and you're done. I hardly ever get a CE, like once every 6 months.
jeff
I never got a CEL with my testpipe....At least not one related to the testpipe. OMG :cool:
Later,
Mine tripped and I reset it and made the gasket at the test pipe leak and it hasn't come on since. I've done plenty of trips to race tracks and so forth its been a few months. Haven't seen a check engine light since.
I still have mine in place and got a CEL for the first time today, I think cause i was staying around 60 with no boost for awhile. I don't know exactly when it checks it but its really weird situations like this. I just reset it and hasn't come back since.
-PhiL
The Honda boys have something that simulates the second 02 sensor signal. Some "little black box" type deal. Me, I solved the problem by not owning a 2G DSM, I have a 1G instead. The only problem with that is I can't use my car to get laid because chicks don't like it. Thank goodness I'm so goodlooking.
I know this may sound getto but you can get rid of your CEL for good no matter what. Are you ready?! Clip the wire that goes to the CEL, and wa-la no more light. This is probley only a good idea if you have a pocketLOGGER so you can check to see if you have any.
    • 92AWDHX40
    • eclipsemf
