jonheslop
- 60
- Apr 11, 2005
Wilmington,
Ohio
Here's my situation...I can't get my car to start and I've narrowed it down to the cam angle sensor. This is on a 91 turbo by the way. When I test the wiring it seems fine. There is 12v of power and a good ground. The black wire reads 5v every half a turn of the cas but the white wire doesn't read 5v every quarter of a turn like it's supposed to. That is the rpm signal correct? Anyways, I have used three different CAS's and none of them test right. Am I testing it wrong or do I just have bad luck with my used parts? Is there any other testing procedure I am overlooking? Thanks for the help. Jon
