MarkAngelo05
- 201
- 2
- Nov 7, 2006
Pearl City,
Hawaii
Hi!
First of all, thanks for taking the time to read this.
I decided on rebuilding my 7 bolt motor rather than swapping the 6 bolt in it. My 7 bolt has about 117k miles on it, and the head (which I just put on) has 8k miles on it.
Problem- Compression checks out at around 125-130 psi on all 4 cylinders. I add some oil, then it bumps up to around 150 psi'ish... I'm also starting to burn some oil.. so this tells me its time for the bottom end to be rebuilt.
I've been boosting 18-19 psi on this block for about the past 10k miles, and (cross my fingers) have not had any signs of crank walk. I also have an upgraded clutch which claimed 18% more holding capacity than the stock clutch. (XTD stage 3, 6 puck sprung disk clutch kit) which has been on there for about 8k miles, still running well and not slipping at all.
I recently changed the oil and my magnetic oil plug seemed to collect very very very very little amounts of metal contamination
I recently dynoed 260 ish whp at 19.5 psi on my current setup. I would like to achieve the 300whp area with a "fresh" stock'ish build.
Now for the questions--
I'm shopping around for new pistons, bearing set, piston rings, and I am most likely getting some stronger rods.
I am a little confused about the measurements and tolerances. On all rebuild kits, and even buying parts individually it asks you if you want ".020, .050, STD, etc etc" How do I know exactly what to get? specially for the thrust bearing/washers, main bearings, and piston/rod bearings...
Do I have to actually take my engine apart, get it hot tanked and cleaned out and have the parts checked and measured before I order my rebuild kit?
I'm set on staying at 8.5:1 compression, so are stock 2G pistons made by topline okay? Does it make any sense to stay with 2G pistons w/ Eagle rods, or other stronger rods since 2nd gens are known to have weaker rods?
I'm doing the balance shaft eliminator kit as well. I'm going to reuse my arp head studs, but I'm trying out the new SCE ICS Self sealing head gasket, (recommended by Maperformance)
Thanks in advance for all your help!
Aloha from hawaii!
Mark
Aloha from hawaii!
Mark
