Mitsu MLS Gasket, to seal or not to seal......
Seal or No Seal (Mitsu MLS Gasket / ARP Studs)
  • Use Spray-On Sealer
    Votes: 11 84.6%
  • No Sealer / Gasket Only
    Votes: 2 15.4%
  • Other (please specify)
    Votes: 0 0.0%
  • Total voters
    13
  • Poll closed .
Thomas91169
4,490
28
Jan 18, 2004
modesto, California
Ive searched around and it seems that everyone has mixed feelings.
I will be installing a Mitsu MLS gasket with ARP studs on a freshly resurfaced head. the block however will not be resurfaced but i will clean the mating surface as much as possible.
Should i use a copper spray-on sealer or not?
I say use it. Make sure you spray it all over everything, the pistons, the valves, make sure you get some on the cams as well, just to be safe.
