Max Psi On 14b?
LAZPNO
162
Aug 9, 2002
I'm trying to build the car up over the winter and see what it runs after that. Gonna make sure everything is good first. Anywayz, 3" turbo back w/ ported 02 and supra fuel pump (hardwired) will be done in Jan. After that i was wondering the max psi i should be capable to run without leaning out the engine, this is without fuel controller and using stock injectors.
Hacked air can.
K&N filter.
P.S. i plan on leaving the MAS alone until i get an afc and 550's or 3kGT injectors.
Thanks for the info.
not sure, but i know that this question has been answered more then enough times. do a search for it.
I think efficiency on the 14B starts to fall past 15-16 psi .. I've heard of people bosting a 14B to 21psi, but I think your just pushing hot air at that point and without a large FMIC it will do you no good.
16-17 psi on pump. If you have a modded sidemount, 18 psi. Front mount with 550 injectors and a AFC, 20 psi max. At 20 psi, expect the life of the turbo to decrease and porting is recommended. I would rather upgrade the turbo than run a 14b at 20 psi though.
Just my .02 and have a nice day!:thumb:
