Upper I/C Pipe Installation
Xero_Tolerance
145
Sep 27, 2002
Austin, Texas
Hey, I just got the Dejon Tool Upper IC Pipes. I tried to install them the other day, but I couldn't get off a few of the bolts. Does anyone know of the easiest way to get off the bolts under where the S pipe connects to the engine on the top, and then there are a couple bolts that connect the stock plastic IC pipe to the car. Those four bolts seem practically impossible to take off, if anyone has any good ideas on how to go about getting them off I would appreciate it a lot, thanks.
www.vfaq.com
there is faq on there for the brode and burschur pipes. Either one should help you out. It isn't that hard if you take out the airbox and other things to get them out of the #@%#@%#@%#@%ing way. You need some open ends and a ratchet with extensions. Do you have an intake? If not, you might have some problems getting the airbox to fit with the pipe.
It isn't a hard job, just make sure you get it right the first time so you don't have to take it all apart again because you didn't get the couplers on right.
Later, post if you have any problems
yeah it's easy man. I was just doing it the other day, 1/2 socket, metric not standard, and they came off, the l pipe was pretty easy too, tho I had to put the old ones back on cause i wasnt to wait for my new bov to have welded on the L pipe. doh!
