Full Race Tubular Manifold + Mitsu housing
dalatinromeo
889
26
Nov 18, 2004
Fair Lawn, New Jersey
I plan to purchase a tubular manifold some time after my turbo purchase. I plan to upgrade to a PTE 5031 and then a FP 3065 after. I was going to buy a DNP turbular mani, but I after talking to a friend, and looking thru their website I think I want to get my tubular mani from Full Race.
Okay heres the problem when I went to their website I noticed they only offer turbo flanged T3 OR T4. Does anyone know if they make one for a Mitsu flanged turbo??
Might as well go t3 or t4 now. The are all more efficiant and there are so many more other options to upgrade. You can get any pte t3 or t4 turbo from Arturbo.com for $730 shipped. So you wont be spending any extra money go with the t3/t4 setup.
but the only reason most people stick with a mistu style is the cost of replacing the manifold , o2 housing and usually getting an external wastegate, you are allready getting a new manifold probably externally gated and looking to upgrade your o2 housing or will later then it would be perfectly fine to go to a t3/t4 style turbo.
bullseye turbos make a turbine houing that bolt to a t3 manifold and turbo.but still take a factoryo2 housing.call bullsseye and talk to david
The FP3065 will not bolt onto a T3 flanged exhaust manifold. The alternative you'd be looking at is the GT3076R which is the same thing in essence I believe (same compressor dimensions).
And yes, you just need a matching O2 housing and a way to connect it to the downpipe for it to work. You can call Full Race to see if they'll make one with a Mitsu flange, but I don't see why you would do it since the full Garrett setups are generally much better. Full Race probably won't do it either since they design everything through CAD and have it machine tig welded, meaning it would be a pain in the ass to set up.
I have a full-race t4 manifold on my car right now. They dont make a mitsu flanged one, they dont even make a downpipe for the t3 flanged. They said they didn't have a test car in the shop long enough( they work on hondas all day) It places the turbo low enough so everything will clear even with an S housing. If you already have a 3 inch down pipe just buy a flange for the turbo and a 2.5 inch 90 bend and make your downpipe one piece. If you don't know somebody that can weld an exhaust shop will only charge about $50 or so.
PM'd you about manifold fabrication.
I wouldnt even bother going with a tubular mani with a mitsu flange.when i upgrade to a turbular mani ill go t4.But for now i have plenty of power (high 500s)with my evo3 manifold and GT3561 turbo.Hopefully itll get the green tank down the 1320 soon and post some results.
