1G Oil Pressure Guage Installation Question
ZiggysDSM
789
4
Jul 25, 2004
Bel Air, Maryland
Ok well I have gone through a ton of posts and I am coming up blank. So what I want to know is if the spot I marked in this picture is ok to tap for an aftermarket oil pressure guage sender. I have seen 100 spots on a 2g to tap but i havent found a picture for a 1g. So if you have tapped it there or know if you can or cant let me know, thanks.
That is an acceptable position. That empty space is also used by some to relocate the feed line for the turbo.
thanks but the reason i ask this is rre said to use the bottom one for better flow
