jim97gst
- 482
- 3
- Aug 2, 2002
Bethel Park,
Pennsylvania
Does anybody have anything bad to say about this intercooler kit?
http://www.extremeintercoolers.com/2g_7_kits.htm
I like the 7" core because it allows more air flow to the radiator (I live in Arizona, I autocross, and I might do some type of track event some day). I have an evo III 16G and I don't think I'll go bigger anytime in the near future. I also like that I don't have to cut a hole in the support. It's not THE SHORTEST short route piping, but according to the guy who makes it, it only adds about 11" to the pipe length to go this way versus the AGP/Slowboy route. It also seems like it would flow a little more smoothly through this part of the path as the air will be going though a mandrel bent pipe rather than making a 90* turn at the end tank out the back of the intercooler.
Any opinions appreciated.
. But seriously a few guys run that setup here & from what I recall only heard good things. As for that routeing, it will still work great. Sure it may add a couple inches compared to the SBR/Kinetic super short route setup but you don't have to hack a hole in the rad support or worry about swapping/moving the coolent overflow. Plus its still shorter then stock. As for only being a 7" tall core, doubt that will make any difference in flow to your rad. 7 inches tall will fill the whole opening in your front bumper right up to the inner bumper support so it would be no different then if the core goes right up into the inner bumper support. Since you do road race make sure to keep as much of the factory plastic shielding around the rad to help direct the airflow into it. Also a good idea to make a plate that fits between the ic core and rad at the bottom, since youll have to cut out the stock one.
