just got a blitz id gauge
Gs-tHaVoC
65
Mar 19, 2002
and i cant find a darn wire to tap to so it will light up. i went to vfaq and it says to tap a fuse but when i do this lights still dont show. any suggestions?
one other thing, should pressure be -0.5 bar at idle or should it be 0 cause mine is at -0.5 until i hit boost then it goes to about 1 bar then drops back off does this sound correct?
Errr forgot to mention should i even bother putting in my mbc b/c i dont have a bov wortha crap yet just wonderin. thanx again
If I'm understanding you correctly you need to run a power wire to the fuse box correct. Just pull your fuse box and check for a fuse that will be on when you start you car such as the windshield wipers etc. then strip the jacket off and wrap it around the metal part of the fuse. cram it back in and turn on your car. It's pretty much like hooking up a tach or some indiglos.
hope this helps
blackdragon013
well i did that and still nothing i put it on with the 10 amp GAUGE FUSE and grounded it with the little nut to the left of the fuse box.
for your boost issues, yeah thats normal. for the other issue.. go get a test light and poke every wire you see till you find one that turns on when you need the lights to turn on on the gauge :) then tap that one. simple.
