jmadison
- 32
- Apr 23, 2005
Iowa City,
Iowa
97gsx
I just put a TRE Trans in my car last weekend, and now when I went to start it up the first time, it hiccuped a bit, and had trouble idling, but after about 5 tries to start and giving it gas when it would turn fully over, it finally holds an idle RPM. I thought this was caused by the fact it has been sitting for the better part of three weeks, bc when i started it about an hour later i had no probs getting it the first try.
But every time i let it sit for prob like 3-5 hrs or more(basically a cold start) it does the same thing. Hard to get it to fully turn over, and then hold an idle. The gas seems pretty much unresponsive until over 2500rpm when i try to give it gas to start up.
The only code i am throwing to my knowledge is a radiator temp sensor, that i sheared somehow while taking out/putting in my tranny. But i dont think this would cause my problem, but anyone have any suggestions?
It idles fine after i finally get it going, and when i try and start it from a warm block.
Someone told me maybe fuel filter, it could be starving it on startup?
thanks in advance
Josh
thanks in advance
Josh
