MarcVIII
- 103
- Oct 23, 2004
Cleveland / Akron, Oh,
Ohio
I bought a downpipe that is suppose to eliminate the cat. I also bought a cat that I wanted to place behind this downpipe. I have two options- chopping the dp and locating the cat where it should be (i want to avoid if possible) OR moving the O2 sensor to hook into the new rear-pushed cat. Both the dp and cat are flanged, so its a little easier.
I am wary of doing this without consultation because I'm not sure if adding wiring would effect the reading of the O2 sensor. I was thinking theres two places to add the wire- the harness before the plug or on the sensor itself. The sensor is OEM, non-wideband. Has anyone done this before or on a different car? Will extending the wiring effect reading?
