NGK BPR6EKN's These the right ones?
ARE THOSE THE DOUBLE PRONGED ONES.
if so then thats waht i have in mine (gst)
the difference between those and the O.E suggested are one or two electrodes(prongs)
tite
darth
ohhh and RE- gap those yourself. i heard that there is a possibility that they can be effected by transportation and the gap will change.
I couldn’t answer you for sure. I know that when I would go out tuning I would be seeing some knock and when I switched to the colder spark plug it all but went away. I needed a plug that cold because I was trying to make all of this HP on pump gas. Might not hurt to give it a try.
Originally posted by 90GSX
With your mods, you should run NGK BPR7ES
What? All he has is a boost gauge. He should stick with the 6's until later when he turns up the boost. I'm no expert certainly, but I think some people flatter themselves and switch to the 7's too early (just my opinion).
You're right, I glanced at his profile and saw his "wish list", mistook it for his actual mods list; a very detailed wish list BTW.
6's would work better than 7's in his stock configuration. Switch to 7's after most of the stuff on the list is acquired.
LOL thank you..it would be alot more detailed if i had the room. They cut me off before i can finish. I just researched and researched untill i found what i wanted. Anywho ya. I re-gapped them and put them in with my new Accel wires. The car runs great. Thanks guys. :thumb:
