2G TPS calibration
L2RTSiAWD
Honorary Moderator
11,533
29
Apr 8, 2002
Chandler, Arizona
Hey Guys,
I'm putting my 2G TB back on and I need to know the factory setting for the TPS sensor. I don't have access to any of my manuls right now.
Thanks,
John
Ok I got some info(thanks Larry). If anyone with a 2G that has a multi-meter can do me the hugest favor and tell me your ohms on the TPS with the car off checking the resistance between terminals 2 and 4. With the throttle closed.
Thanks,
John
Nevermind I got it.
SCREW a 1G TB!!:mad:
I got my 2G one back on and the car idles better plus I think I stopped a big boost leak because I can hear my BOV revving in neutral which I never heard before.
you adjusted the Biss right? I can get the car to idle fine, problem i have right now is the car sometimes stalls out when i put it in neutral...not to mention the problem i have driving and at say 30-40mph which sucks.
Originally posted by GVTalon
I'm not thrilled with my 1GTB either...ever since I put it on, the car idles at 2 grand during warm-up...then when the car is warm it idles normal.
wow, mine does the same thing; thought it was just me.
been thinking about putting the 2G back on, haven't noticed much difference with the 1G (except crappier gas mileage)
The 1g tb will do you know good performance wise unless you have the intake manifold port matched to the head. Of course you may know that already, cause I didn't see anything about one in your mods list. Just my 2 cents worth.
