definitiveno
- 1,237
- 8
- Sep 8, 2004
Reno/Sacramento,
California
Wich downpipe for my gt30r? I understand the exducer on my turbo will be 55mm or 2.2 inches. From looking at the hahn housing the dump is routed in immediatly, pressurizing almost the full leangth of the 3 inch pipe with exhaust. A little bit of turbulance but nice re-entry.
the 122 is only a 2.5 but it dumps right at the flange, once through the flange I can slowly bring the downpipe out to 3 inch. I think I read that the O2 should match as closely as possible to the exducer but I wasn't sure if the same principles applied with internal dump. Wouldn't the exducer and wastegate port have to be calculated?
Where you at Nick, come set me straight already....
What do you guys think?
