johnnytsi
- 176
- 10
- Aug 20, 2002
Everett,
Washington
Grrrrr, I've got a brand new rebuilt engine, I think my new cams are messing up the a/f ration just enough to fail the HC test at idle. My fuel trims are all out of whack with high, mid and low all around 139 all other numbers on the datalogger look normal
the idle limit on HC is 220, and the best I can get is 470. I passed all other tests.
ALL of the stock vacuum hoses have been put back in place, I've blocked off the EGR, the cat is back on the car. I built a pressure tester and fixed the vacuum/pressure leaks in my intake system!
I've been through the test three times now, and got it closer each time.
What can I try now??? So close, and yet so far
One of my buddies suggested dumping a bottle of rubbing alcohol in the gas tank?? Has anyone heard of trying this? Will it break anything?
Any other suggestions would be appreciated
Thanks,
Johnnytsi-
Thanks,
Johnnytsi-
well i wouldnt recommend alcohol...but anyway..my car would never pass inspection in a million years..so i usually get someone to pass it for me...ask around for a mechanic who does that..you'll probably pay a little extra but its worth it..
