Extreme stiff shift kit, install it how?
Remove the intake, you will find the bracket on the tranny held on by 2 bolts, if you remove those two bolts the two bushings come out. Bolt the plate back in
trim the plate if it doesn't clear if you nee to ( I had to do that )
