TSIracer010
- Sep 21, 2002
would a SBR-B16G turbo work right on a stock 96 talon tsi fwd automatic with no mods?
Originally posted by Turbo Guru
No, you would need an install kit to the tune of around $200. I suggest a T-28 upgrade (direct bolt-on) from AGP, Forced Performance, or Turbochargers.com.
Joe
The T-28 is a direct bolt-on whereas the 16G is not and would therefore cost more.
You PMed me with a question of running it with no other mods. I would say that you should do a fuel pump rewire at the least. Also get a boost gauge other than factory and make sure to keep the boost low until you get some supporting mods.
As for how much horsepower you will have after replacing the turbo I would not venture a guess except to say that the T-28 is capable of supporting up to (in some cases) 360hp with the proper supporting mods.
Joe [/QUOTE
What mods would i need to run the boost to up to 300 to 350 hp?
