Poly motor mount Q.
TsiTalon90
159
Dec 23, 2002
Granby, Massachusetts
Im replacing all of them and i got done cutting the front one out near the radiator and the new mount is really weird looking, its plastic and shaped weird its not like the other polyurethane mounts. anyone else have this issue?
jott5555 said:
no the two inserts go in the front motor mount. the rest goes in other mounts.
There are 3 that are the slip in kind and there is one that is the other kind he is talking about. All the slip in ones go on the sides and front mounts, the other one goes in the rear by the firewall.
hey man the 2 side motor mounts and the back u have to cut outthe whole rubber mount inside! the front one you leave the rubber inside it, and press the inserts around the stock mount!
I believe the poly mounts have differences between the 1g and 2g setups, the 1g has a full urethane replacements for three of the mounts, rear, left, right with inserts for the front, not positive, because I have a 2g.
On the 2g prothane setup, however, there are two piece inserts for the front and rear (no metal sleeve, much thinner) and two piece full mounts (metal sleeve) for the sides, I am installing mine this saturday.
I will report to this thread on my experience. RRE has info on the differences, somewhere on there site, as well as, the prothane vs energy suspension kits. If all else fails call them up and ask em'. hope this helps.
Wow.... Dude, don't leave shit in. Make sure you take a tourch to them, take out the old rubber "inserts" then the steel sleeves. If you don't take out the steel sleesves, then you end up having other proth. MM fitting inside of others; creating twice the work...
Ya thanks they are just inserts, but i already cut that one out as u can see, its not to bad ill c what i can do to fix it.
Thanks for the help.
