Help! Above 14-15psi, or WOT, car makes put put sounds out of the exhaust & stutters
Okay...3" turbo back, 2.5" uicp set for blow thru, maf translator 2.01, small 16g, walbro 255lph fuel pump, 560cc injectors, mbc.
I just installed the walbro 255lph fuel pump and 560cc injectors yesterday and finished them today. I have the base setting on the maf transltor v. 2.01 at setting D (560cc injectors) The idle seems fine, mid throttle seems fine, but as soon as I floor it and the boost gets above 15psi the car makes a put put sound coming out of the exhaust and Idk what it is. Simultaneous with the put put sounds the cars acceleration stutters like hell and it doesn't pull at all. I do have a data logger but I changed the batteries and it erased the software which I'm gonna install at my friends house later. Do you guys have any idea what could be wrong? Idk if it's running rich or lean or what? By the way I'm running on 91 octane gasoline. Or is it something faulty with the bolt ons? I'm still on the stock 02 housing so I get boost creep at times, but Idk if that has anything to do with it ### I haven't seen the boost spike past 20psi, and I've got the fuel to support it. Once the put put kicks in the car won't boost past 15, I have no idea what's wrong. And I don't want to f the engine up. Can you guys help me out? Thanks~Brandon.
P.S. All injectors are plugged in, fuel pump is in right and works ( I can hear the whine)mbc and intake piping are all secured and not leaking.
P.S.S. This isn't a big problem, but the car reads Empty all the time now lol, did I bend the floater or is it stuck?
