91gst
- 112
- Dec 19, 2001
Miami,
Florida
I just installed my front mount and on the j-pipe where the vacuum line from the boost controller goes there is no nipple there to plug into to send the signal to the boost controller and then the wastegate. On the stock intercooler lower intercooling piping this is where it used to be plugged in. So right now there is no control on the boost and I haven't been able to test out my front mount. I am wondering if I could hook this vacuum line to the vacuum line on the top of the blow off valve or should I get the nipple cut off and then rewelded on the j-pipe. In the manual it says it has to be installed on the pressurized side of the turbo. Please help. Thanks
I am reading the chapter on boost control in Maximum Boost to try to understand the concept a little better before I connect my AVC-D. Does anyone have this and can explain the purpose of scramble boost setting and how to set it up on the back?
