Evo III 16g Gate Pressure?
TurboBlue
654
Oct 25, 2002
Canton, Connecticut
I recently put a 255, fmic and evo 16g on my car, but since i still have the 450's, i got rid of the MBC and just T'd my BOV vacuum line to the wastegate. I was told this should produce about 12 psi...any one know if this is accurate, and if not, what sort of numbers are more realistic?
mine is 12psi i am running just about the same setup but i have not put in my 255lph pump yet cause i hear it does not run well with out a fuel pressure regulator. i have a 3" lt1 with a MAFT ram chargers but even at 12psi i still hit fuel cut but i don't knock and i run on the rich side of things to redline with the data logger.
:laser:
It's between 11-12 psi.. But it's actually suposed to be 11.1psi. I havnt hit fuel cut yet on my setup. Hope this helps.
well, turns out to be just about 10-11 psi, no fuel cut, and runs fine without an AFPR
i also get between 11 and 12 lbs of boost without a mbc. i am also still running stock exhaust (for now), had to replace my dead 14b. :talon:
