REDBLUR
- 220
- Apr 25, 2002
I found the boost leak on my car and its coming from my turbo(stock 14b). The leak is where that huge snap ring is inbetween the turbine housing and center section. There are no visible cracks on the turbo (I pulled it out of the car).
What would cause this??? I dont have the cash for a turbo upgrade right now (school) and dont want to drop $100 to rebuild a 14b. I was planning on taking it apart, inspect it, port it, clean it up and put it all back together hoping it wont leak. What do you guys think??? Is this a common place for a turbo to leak??? After I installed my MBC and set it at 15 psi, I would hit 15 psi and it would violently drop down to 8-9psi. Using an intake leak tester and some soapy water I found the problem.
Input please,
thanks
Input please,
thanks
