Need someone to take the head off of my 4g63 in Ohio area?
JJay
786
Oct 11, 2002
ATLANTA, Georgia
My car recently jumped time and I found a place to fix the engine. I am not getting any compression and some of the valves are bent. I found a machine shop that will replace the gaskets and the valves. Bottom portion of the engine is intact so I just need someone to take the head off.
I can't do it so if anyone is interested in making some money. Let me know what you would charge. I am located in Cleveland, Ohio email. I need to get this done as soon as possible.
Thanks :thumb:
Do it yourself and save that money to buy an upgrade or to fix a future broken part. Unless it is absolutely impossible because of time, do it yourself. You'll value the experience like I did.
yeah there is not to much to it, remove the belts, take valve cover off, take cams off, make sure timing marks do not move, remove the head bolts (your gonna need a 12 point socket) head should come off now with maybe a little bit of help with flat head screw driver, put new head gasket on and reasemble once you have fixed your head or have a new one.
