2g PORTED MANIFOLD WORTH IT?
nore474
Mar 14, 2004
clifton, New Jersey
I have a 1g as you can see from my sig and I was looking into getting a ported 2g exhaust manifold, a lot of people say it doesn't add horsepower it just helps spool faster, is it even worth getting, did anyone notice any horsepower gains?
The port design is a little more efficient on the 2g and less prone to cracking. It might not make a big difference in power but you will have to replace your 1g when it cracks so be on the lookout for a 2g as a replacement.
Have you checked your mani yet? Out of the 3 1g cars I've had, all 3 had bad cracked manifolds. Also expect to be leaking out of your manifold/head gasket also, all mine have had a few broken studs and they leak when it happens. Good Luck :thumb:
