eclpsegsx12
- 214
- Feb 16, 2003
Tucson,
Arizona
My motor is ready to go and i have everything but my AGP 50 trim kit which is on the way. I was told numerous times to run a 14b for break in so any metal shavings wont wreck my new turbo. I want some opinions or first hand experiences on what they did. I have everything for the 14b but that means ill have to take everything back off and swich turbos. If i change my oil right away after startup, will i be ok running the AGP turbo? It just seems like a lot of extra work but it is worth it?
Also, about the non-water cooled 14b thing. I have a 14b but i wouldnt be running water through it because i have a NT water neck with no outlets for it when i put the 50 trim on(which is oil cooled only). If i do decide to run the 14b for a while, do i need to block off those passages for coolant thorugh the turbo? It didnt seem logical to me since coolant wont be running through it anyways. I have 2 stock turbo water eye bolts that are in the places for the coolant but it they dont go all the way in anyways because they are too long. Thanks guy.
