6 or 7cm housing, how to tell
nazthug
478
8
Dec 24, 2003
livermore, California
are there numbers on the turbine housing that tell if its a 6 or 7cm housing? Just wanted to know so i can tell for sure before i buy a turbo from a local guy
its been ported so there realy is no way to measure is there?
The number "070" or "060" will be on the turbine housing depending on whether or not it is a 6cm or 7cm housing. Here is a pic showing where to look for the number.
Well if its been ported more than likely its a 7cm opening. If you post a pic we can tell you right away its a no brainer to see the diffrence.
