pimpngear
- 101
- Jan 22, 2003
Arlnington,
Virginia
Just like the title says. Awhile ago my car significantly overheated. I ended up decking the head, changing valve seals, water pump, timing belt and such. Being the inexperienced 7bolt engine builder, I broke the Cam Position Sensor. I replaced it, and the car still ran poorly. After many different possibilities, I ended up adding a 1g CAS using RRE's technique. Car idles and runs, but rather poorly.
When I get in it the engine feels like it is misfiring at the higher psi levels. Ive used multiple sets of plugs, because after a few miles of running them, they are completely black. The car smokes like a mother. Timing is dead on @5deg BTDC, and all the bad gas has been ran out of the car (intentionally). Compression check showed me with 190 low and 194 high, so it cant be my rings, or valves.
The car seems to only have the timing issues under higher boost levels, but everything is sealed up tightly. The car smokes real badly, but the turbo has exactly no play in, out, up, or down. With a gallon of 93 and a pint of +7 NOS I was still not able to prevent it from smoking.
Has anyone successfully done the 1g CAS in a 2g, and if so, did it work for you? I just need a few new ideas, cause believe me. I am all out.
