Mbc
wishIhadaturbo
117
Jul 14, 2002
Dayton, Ohio
I spent all day trying to find a sutible valve to use as a MBC. I went to Home Depot, Lowe's, and True Value. No had any idea what I was talking about. What application does the valve have, or what else is it stocked with
TIA
Will
Just make your own. A brass T fitting (be sure to drill out a VERY small bleeder), a couple of barbed ends, two ball bearings, a spring, and a drilled/tapped end for the adjustment bolt. See:
http://www.geocities.com/chmwatson/FAQs/mbc.html
If you really want a pre-made valve, go to Grainger; here's a quick URL to help if you're looking at getting one of those:
http://www.xmission.com/~dempsey/perform/grainger.htm
Finally, here's a page I tracked down just now with a ton of links to boost controller information:
http://www.fwdmopar.com/sites/dennis/boostcontrolbible.html
Hope this helps.
