xhypno
- 186
- 4
- May 12, 2002
Pembroke Pines,
To increase boost on street gas with out detenation, is not an easy task, but it can be done. There are 3 ways to do it, and all 3 at once is the best way.
1.> Bigger injectoras and Pump = more fuel and less chance of going lean
2.> Water/Alchol injection = same fuel, cooler combustion chamber that uses fuel better
3.> Cold start injector riged to a pressure switch = more fuel when needed, saves gas
These cold start injectors were used on late 80's volvo's and vw's. It allowed more fuel into the engine at start (allowing it to start easier). But when installed on our intake manifolds and rigged to a pressure switch, they will add a large amount of fuel that will stop detenation.
thanks for the good laugh
at NosLaser..not saying he is lying *sigh*, but I bet he didnt expect you to know the guys at that shop..
