sophat34
- 321
- 1
- Apr 10, 2002
poynette,
is there a diffrence other than the oil pan in the short block alone with out any of the front cover parts and disregarding internal parts? oil lines, coolant lines, ect...
turbo blocks have a knock sensor bung, non-turbos don't (although there is a way to use the stock knock sensor but don't ask me how).
Thank you for trying to clear up misinformation by reviving a ten year old thread that very few new members would have ever searched for and actually found.
Now, since you've resurrected it and the likelihood that newer members may stumble across it has subsequently increased, let's set the record straight(er): some non-turbo blocks have the knock sensor bung tapped and ready to accept the sensor from the factory.
Knowing this, if the block doesn't have it tapped and ready to go, one can be reasonably sure that the block is a non-turbo as ALL turbo blocks should have it. Since some non-turbo blocks have it, one must look for other signs to confirm a turbo block; at the end of the day, the VIN or oil squirters check are the easy ways to go.
http://www.dsmtuners.com/forums/newbie-forum/249773-what-diffenent-4g63t-4g63.html
http://www.dsmtuners.com/forums/newbie-forum/234606-knock-sensor-hole-nonturbo-block.html
http://www.dsmtuners.com/forums/cylinder-head-short-block/390960-block-identification.html#post152448801
