91 TSi awd auto only works in 3rd and revurse
99 gst 420a dsm
509
2
Jan 22, 2003
Turboville, New York
This 1991 TSi AWD with auto transmission only works in 3rd and revurse, whats the problem? the last owner said it was one of the three sensors or something in the transmission, it dosent slip, just only will drive in 3rd and revurse
It sounds like it's in limp mode. You will need to check the TCU codes.
-John
The last owner said it had a bad servo, if that could be true i have an auto trans from a 93 eclipse 1.8L if i can use the servos out of that-that would be great.
If you don't check the codes you are essentially trying to piss up a rope, from a diagnostic standpoint.
-John
