what's the biggest wheel for a 1999 GS?
Uriah RR
Nov 23, 2003
I have a 1999 Mitsubishi Eclipse GS Spyder, and I was wondering what the biggest set of wheels I could put on it would be. I was thinking about 19", but that might be too big to fit under the car or look goofy. Any suggestions?
Don't stop at 19", go at least with 26" rims
For real though, 19"'s do fit.
Here's a pic of them:
Cool dude thanks. And about how much did the 19" rims and the low profile tires cost you?
24'' spinners yo :D ive seen 20s.. to do that you ned to roll the fenders and cu away shit - you will prob need to roll fenders with 19s.. not sure depends how wide you go. some peoples 19s rub, some dont. 19s run anywhere from a cheap set for maybe 1000- an expensvie se of racing rims for 3000+ average set will run you 1300ish - like the kind wiggy has, konig tantrums, i myself was going to get those rims, they are like 1400 for 19x7.5s i thnk... low pros will run from cheap tires at like 50-60 bucks a pop to 300+ for a tire, average, maybe 100-150 each - i recomend going with 225(215 if your cheap, 225+ if your running anything wider than 7.5ish or want some serious traction)/35/19
hpe that helped somewhat. :dsm:
All right, cool. I'll have to measure mine up then. I have 16" on now. What size do you have?
