Removing Seatbelts
dsmnate
415
May 9, 2002
Hershey, Pennsylvania
Does anyone know the trick to removing the front seatbelts so that you can take off the interior trim that goes around the rear quarter window??
I looked at the housing that slides up and down on the side of the car but cannot see a way to pop off the plastic housing on order to unbolt the seatbelt.
Thanks
-Nate
in the housing is a crack where the 2 pieces snap together. the way i did it i took a screwdriver and pried them apart. you'll have a bolt showing after that and just undo that too
how exactly do you take the whole seatbest assembly off, I want to be able to wash the seatbelts today...what do i need to do???
Well you remove the back seats to get to the bolts and screws for the plastic piece under the rear 1/4 window, then you remove that plastic piece. That will expose the screws for the plastic around the rear 1/4 window. Take that plastic off. Then above the seatbelt, there is a little plastic piece that snaps in over the upper bolt for the front seatbelt (same as in the back). Pry is off with a flathead screwdriver. Now you will have to get a wrench to un-do the top bolt for the seatbelt and to un-do the bottom bolt for the seatbelt near the base of the back seat. Then there is one more bolt on the floor by the door. Sorry for the length but I hope it helps.
thank you, i got all the paneling off, but now i am trying to figure out how to wash the seatbelts...HELPPPPPP
I would use some powerful hand soap and a toothbrush, maybe even a wire brush. Or you could also buy some heavy duty degreaser and soak them in a bucket overnight.
AdoreGSX said:
what about that contraption that spools the belts up???
Hmmm... You could probably soak that too, if you dry it thoroughly after, but I would just un-reel the seatbelt, clip it off somehow so it cannot roll back up, and just hang the spool outside the bucket, or do not wash it. And I wouldn;t worry if you do not clean a couple of inches close to the spool, because that will be behind the plastic and not showing anyway once you get it back together.
