S-AFC 2 , AVC-R and T.T. install Q's???
ProjectTalon130
365
Jul 16, 2003
G-bury, Connecticut
Hey guys, just want anyones thoughts on where the best place in my 2G is to install all 3 of these so they are somewhat visible BUT DO NOT replace any vents or hack apart anything in the interior. I just want them to look clean (not too visible if possible from outside the car) and somwhere that requires no modification and if any just swapping or pulling out parts, not cutting them up (don't feel like spending much if any money on things like the AFC carbon fiber thing $200) and it takes the usefullnes out of the vents there....Any ideas or methods (areas) that you tried that worked good let me know (what thinking of the center console since the dash is pretty swamped with buttons already) would the empty spot under the aftermarket Head unit work for atleast one controller or is it still too small??? thanks in advance.
P.S.- where are there any holes in the Firewall to run all the wires to? and would that little space in front of the shifter before the stero work (near the cig. lighter for one of the controllers?)
that slot is a bit to small, with soem fiber glass work you could make a mount that stuck out a bit and place them both there, but there really isnt much room for both of them out in the open. I have seen some with one in the glove box and one in the plastic pannel nest to the cigeret lightter. that involves some cutting, that or make a fiberglass or abs peice to replace the ash tray and place them both there. just some ideas. I'll see if I can find some pics
ok great, thanks for the input, i really would like to have them where the ash tray/cut holder are because it would be sorta sleek and conveinant to control...the glovebox is hopefully just a last resort. Any ideas of some Home Depot stuff that could make a professional looking replacement right there for all 3 or just the 2 controllers??? Kinda budgeting my self after all the big purchases as of lately.
